Looking for some ideas for a possible fix. I have an '08 X2 with the MCX and the closed cooling system. Last season, I had a problem with the exhaust manifold elbow (plastic composite) melting. It was near the end of the season, so I replaced it with an iron elbow to get me through the weekend and took it to the local MC dealer to get it fixed. They determined that there was air in the system, and took off the heat exchanger and raised it above the manifold to get the air out of it. They did the winterization at the same time, I didn't get a chance to verify the fix. I got it out this season and the first day it lost about an inch of fluid from the reserve tank in one day. I topped it off to the cold line the next morning, and by the end of the day, approx 3 hours motor time, it was down again by about the same amount. Topped it off again and added a little more and took it out again. This time, after about an hour, it started blowing steam all over the inside of the engine compartment (same as last year) as the elbow melted again - so not fixed. The temperature gauge read around 165 and there were no alarms.
I'm in Michigan, so the dealer doesn't work on the CC systems very often, and I'm looking for some advice to help resolve the problem. Any suggestions?
