A shoot out on this test has been done on engine masters
https://www.youtube.com/watch?v=2sQJPZYSoUI
On this subject though I have to weigh in.
Take it for whats its worth; Im a calibration engineer. and work at the OEM level "tuning" engines.
Ok so that's out of the way.
First off, please don't compare a new modern carb to really what is the first iteration of mass produced EFI, the TBI. Simply not a fair comparison. I read a comment that it was done for emmissions. Yes, duh. When you have a tip out, or go into decel how do you do a fuel cut off on a carb? You dont, you are pulling fuel through so its wasted. There are other things to mention that are small that add up to a large amount, but we wont go there. Emissions drive everything we do. Making big power is easy. Making things drive awesome is easy. Doing both those while maintaining emissions is why OEMs hire so many engineers and why things cost so much.
Performance--> watch the video. Ill say that much. Now with really large engines like in dragsters, Carb does have its advantages. You can argue fuel atomization is better and getting a better burn at WOT with a carb. Also, at high rpms and really high mass flow rates of air, EFI is essentially just hosing as much fuel as possible, so why not carb it. Also at very high rpms you need better tech to "see" the rpms accurately. This is cost and complexity that doesn't add much value. Jets are also cheaper than new injectors.
That being said, if you think mechanical adjustments are more accurate than a processor, you are crazy. When I calibrated transient fueling on a modern engine (accel pump and correlated jet on your carb), I have full control of EVERYTHING. Based on map and rate of tip in, I can predetermine the amount of fuel the engine is receiving. Im also compensating with how hot/cold the engine is and theoretical fuel density and air density. How are you possibly doing that better with a carb? In my world, I can make that feature work like a carb but taking all my tables/maps and just throwing one value in (ok not nearly the same because your feed rate on the accel pump is based on throttle tip in, but you cant really compensate for other factors like I can). That being said, I realize the control software I deal with is way more complex than off the shelf EFI from holley or other guys. Even then though, they still have compensations tables/factors that help you adjust for different variables. Its simply not there on a carb.
If you think a carb is better than EFI then you must be comparing a well calibrated carb to a poorly calibrated EFI system.
lol what the hell does this even mean or imply? Do you carry a carb rebuilt kit, cleaner, and jets with you on the boat?
Has anyone on here ever attempted to install a Chrysler 360 marine engine into a Pro Star 205?
No
I've found one that has a Chevy 350 with a cracked block. I'm really a Mopar guy and thought it would be unique and cool to have one in a 205. Is it possible to do and will it bolt up with a different bell housing to the trans? Yes
Be honest though, you arnt going to do this. Get a new block, get the boat fixed, and get sking. Keep the resale value; get on the water quicker; and save your money. IF you really want a mopar powered boat they are around. Keep looking and pick up one when you find it! Lots of prostars around with special ordered engines. These will maintain value, because you never actually keep the boat your whole like you think you will now. You will get lowballed to death when you resell and nothing is original!
Seriously, who wants to bring a scan tool or laptop to the lake with them? That's a nice setup you have though.
No
