2002 X-Star 330 hp engine replacement
  • 2002 X-Star 330 hp engine replacement
    My 02 X-star suffered a catastrophic failure at the end of last season. The engine is not out yet but there is a nice hole in the side of the oil pan and the dipstick is bent and twisted up pretty good.
    Are these the correct replacements?
    http://www.michiganmotorz.com/vortec...rent-p-68.html
    http://www.michiganmotorz.com/350ci-...ent-p-109.html
    $500 difference in new and remanufactured... opinions? I lean toward new.
    Are there places other than Michigan Motorz I should be shopping also?
    thanks in advance
    Dean
    2002 X-Star
    1993 Prostar 190
    Do you know for sure that you need new heads and valve train?
      No, so a short block may be an option. I dont see them on Michigan Motorz site.
      2002 X-Star
      1993 Prostar 190
        In short, buy a new LONG BLOCK GM Vortec marine Motor, you will save time & money. Contact Indmar see what5.7 long blocks they used and go from there. You will have the best performance for the buck.
          What led to the engine failure? How many hours?
          2014 x46
            https://www.mastercraft.com/teamtalk...ad.php?t=83749
            I would be interested in the harmonic balancer and trigger wheel if you end up with an extra.
              Im not sure yet, we dont have it completely out but there is a whole in the oil pan. So I pretty sure i have a rod broken.
              700 hours
              2002 X-Star
              1993 Prostar 190
                I'll let you know what we have left over.
                2002 X-Star
                1993 Prostar 190
                  700 hours
                  please let us know when you find out.
                  Kevin
