2012 X2 Eng Coolant Temp
  • 2012 X2 Eng Coolant Temp
    My 2012 X2 threw a Service Required alarm our on the water when the temperature spiked to 200 on the first run of the season. I immediately took the boat to idle and the temp dropped very quickly. That said, the engine temp stayed back at usual temperatures on the way back to dock. The problem is, I can’t get the Service errors to clear. I have tried the up/down, up down but that does not clear the error although it does successfully issue the reset. Any ideas?
    I believe you have to have the diacom tool to clear the code.
      Yup, dealer came out and reset it. Went ahead and did my annual impeller change at the same time and things are running great again.
      Thanks!
