Can anyone tell me what this part is
  • Can anyone tell me what this part is
    I have a 1997 Mastercraft Maristar with the LT-1 engine. I am leaking water out of the pipe that goes between the heads. They are attached to the heads by banjo bolts.
    Coolant cross over pipe.
      I had an older LT1 my crossover tube was in the back and plugged. I moved it to the front but installed brass fittings and a high temp hose slightly larger passages = less likely to get plugged.
      Sent from my XT1650 using Tapatalk
