Hello,
I had a strange issue today while out on the water. The check engine alarm was going off on my 2005 x10 when it seem to be under load. By that I mean the check engine alarm went off when:
-Pulling a normal size person (~180lbs) wakeboarding at 20mph with full ballast tanks and half full ballast tanks with radio on and also with radio off
-Pulling the same size person wake surfing at ~11mph with ballast tanks half full
-Making a left turn going ~30mph not pulling anyone, just cruising
The check engine alarm did NOT go off when:
-cruising down the lake at 30-35mph pretty much driving straight not pulling anyone
-taking right turns going 25-30mph not pulling anyone
-Pulling someone wakeboarding at 20mph with ballast tanks empty (although sometimes the ballast tanks maybe were around 1/4 full I think)
The engine sounded beautiful and the engine temp right at 160 and the oil pressure was just fine. Didn't see any jumping with the voltage so that seemed fine. The following work was just done in Feb:
-Replace Spark plugs on starboard side and swap out wires and cap and rotor for tune up
-Distributor Cap and Rotor Set
-Exhaust manifold replaced on one side of the engine because it was leaking
So any idea what the issue could be? Here are some the alarm could be from but not sure:
-bad gas? the fuel was treated and there was some recent fuel put it, and the engine never sounded rough
-stereo equipment causing short? I did just add the JL Audio MBT-RX bluetooth adapter, maybe a bad splice? or bad stereo wiring? It is strange because I did have the stereo cut off a few time around the time of the check engine alarm. Also one of the speaker has a lot of static when the ballast pumps are running
-bad wiring for the dash panel? I do have PP but it was put in at the beginning of last season and didn't have any issues.
-anything else???
Thanks for the help
-anything else???
Thanks for the help
