Yesterday on my 1995 Maristar w/ LT1, I was replacing my mufflers with a straight pipe (I have installed a fresh air exhaust, and FAE creator suggests quieter performance with a straight pipe) and I noticed my wet exhaust hose was deteriorating and actually had a hole in one of the corrugations.
1. I found this hose at skidim and wanted to make sure this was a proper replacement that would be able to make the angle of turn, off of the risers turning towards the back of the boat.
https://www.skidim.com/prodinfo.asp?number=MPI252-3120
2. Also, since I was planning on installing a straight pipe instead of having mufflers, is there any reason I couldn’t or shouldn’t run the new hose all the way to the exhaust flange exiting the boat. This way there are fewer joints with potential for leaks or failure.
Thanks in advance!
Thanks in advance!
