Happened to us today on our 18 Star. My husband hit the center button on the throttle and but it in gear to the motor but still remain in neutral. Clicked it back into neutral and started right up.
How many hours do you have on your actuators (surf tabs)? If over 100 hrs, you may have water in your harness that runs to your electronics in the engine compartment. This is a known problem. My dealer told us to plan on changing out the actuators and harnesses every 100 hours until Lenco improves the design. Have had this same issue on the last two boats, (2017 xt21, 2019 XStar).
Find us on Instagram @Bee_Boss_Surf
Brynlee 7yrs, Boston 6yrs
SoulCraft Team Riders
2020 MC XStar white / Grey (Harley’s)
2021 MC X22 white/ Kahuna
2021 MC XStar Red
2021 MC XT22. Yellow/Silver
2020 MC XStar Blue
2020 MC X24. Navy/Silver
2020 MC XStar Red/Black
2020 MC XT22 Red/black
2019 MC XStar Blue/White
2017 MC XT21 Black/Green
2001 Calabria Pro V White/Yellow
I miss read... another post.. all those things will work with a battery that won't turn it over.. put a volt meter across the posts.. what is the voltage?
my bet is a dead battery.. probably dropped a cell. if it shows 12v take it out and have it load tested.. start with the easy stuff first...
Start by checking for the neutral position switch on the transmission.
The purpose of this is to prevent the engine from cranking when in gear (so you can't for say accidentally start the engine when your kid put the throttle forwards and people are swimming)
Because this part causes that problem (purposefully) it is an easy spot to start - it can be bypassed easily by putting both wires on one screw terminal.
If that doesn't do it work down the line - get a voltmeter and see if power is getting to solenoid or not.
Dealer came today. They brought batteries just in case. Didn’t solve the problem. Verified neutral switch is ok. Also checked kill switch. That’s fine too.
It appears that the signal isn’t getting from start/stop button to the starter solenoid. No faults though on PDM or EPDM diagnostics pages. Tech is thinking a starter relay or EPDM. I’m wondering if there is a true start relay or if it’s a virtual breaker in the EPDM. Tech plans to call MC Tech line and Ilmor in the morning. Hopefully they’ll have some things to try.
Before I bought the boat I had the dealer do a bulletin to the tab actuators. IIRC, it was a wiring mod rather than new actuators? Boat has 125 hrs. Only 16 hours since the mod. Which wiring could be damaged as a result of the actuators and wiring? For what it’s worth bilge was dry when this all started.
Appreciate the responses. Hoping this gets wrapped up in a couple days. Currently vacationing with friends and family and not having a boat while at the lake is not how I wanted to spend my week. Very sad faces around here!
