The saga continues! I think I am unearthing pre-existing issues with my 93 PS205, 351W. This offseason I installed a bunch of new parts: Edelbrock 2181 manifold, Quickfuel M600 carb, fuel pump, circ pump, raw water pump, Db electrical 105A alternator. The boat runs great initially - fires right up, pulls hard to WOT. However, it starts misbehaving after it's hot - say, after pulling skiers around for 30-40 mins.
First symptoms are loss of power and chugging when taking off and rough idle. After shutdown at this point, the boat will not start. It turns over easily and I can't see flooding - there is fuel in the manifold when I open the throttle but it is not dribbling or excessive. So, I believe I have an electrical issue.
I replaced the ignition coil and plug wires with new and inspected all the plugs, then went out and ran it hard for about 20 minutes today. I shut it down and let it heat soak for a bit, and it refused to start through multiple attempts over an hour. I pulled the #5 plug to check for spark, and it was only getting a weak spark every 3rd turn or so. When I had that plug out to check, it finally wanted to fire so I reinstalled the plug and tried to start, but it wouldn't turn over at all. Figured I had killed the battery so I hooked up my jump box, and it started after two turns! Ran OK to get it back on the trailer. I checked the battery voltage with a voltmeter after and it showed full! 12.8 volts. It's a 2.5 year old Exide dual purpose AGM battery.
I also checked the voltage at the ignition coil positive and it's about 10.5 volts running. I think this might be the source of my problems - ignition is not getting enough juice. I believe I need to:
-Replace ignition switch
-Add heftier wiring from ignition switch to wiring harness
-Get a new battery
-Probably replace ignition module / distributor
Any other thoughts? This has been driving me nuts but I'm certain I have some kind of electrical problem. When it's started, the boat runs great.
-Get a new battery
