impeller
  • impeller
    My 2012 x14 engine heats up when idling. The water pump is working be the impeller gets eaten up. I had the same problem with my 2011 prostar. Same engine and water pump, Sherwood. Has anyone else had this problem and a cure ?
    Sounds like your impeller isn't getting any water.........which would make it get eaten up and hence your motor run hot. Maybe check the hose leading to the impeller housing or the cup below for an obstruction.......if that's not it, to me if it's getting chewed up and has water in it, your housing may be messed up......
      Yes something is keeping the water getting to the impeller. Check strainer make sure gasket is on it.
