Ilmor MV8 Engine Fault Codes - Indmar ECM Fault Codes - Service Manual v1.2
  • Ilmor MV8 Engine Fault Codes - Indmar ECM Fault Codes - Service Manual v1.2
    For those that have the Ilmor MV8 Engines years 2011-2015 you may have an Indmar Electronic Motor Controller onboard. The fault codes reported can be found in this manual:
    Indmar Marine Engines
    Service and Diagnostic Manual
    For Electronic Fuel Injection Systems With
    Indmar Electronic Control Module
    Version 1.2
    https://www.scribd.com/document/3370...al-Version-1-2
    2013 X55 6.2 OPS & Gen 2 Surf System
    Home Water: California Delta
