Hi everyone. I just installed a new alternator but my battery is still not charging and I need some help trouble shooting the issue.
The boat 94 ProStar 205 with LT-1. Last week the alternator died and after making sure I don't have a loose wire I ordered a new alternator from DB Electrical. I ordered this one:
https://www.dbelectrical.com/product...si-95-amp.html
I installed it today and while I was at it I also replaced the tensioner and the belt. I also upgraded the orange wire to 4GA due to the larger output of the alternator. I had a bit of trouble with fitment of the alternator because the grounding screw was in contact with the bracket, to the extent that I could not thread in the second mounting screw. I ground out the grounding screw housing a bit to make sure I can bolt on the second bolt.
However, I ran the boat and the new alternator is also not charging. I measured the voltage at the alternator and it was 12.3V, just about the same as the voltage at the battery. Since there is no voltage loss, that leads me to believe the new alternator is defective. While I was replacing the orange wire, I looked at the wires/connections on the chain between the battery and the alternator and all looked fine - tight, no signs of corrosion, no kinked wires. I ran out of daylight but will triple check in the morning.
Since the voltage at the post at the back of the alternator is 12.3V, it would appear the alt is bad, not the wire connections. I would think that if the alternator is working properly the voltage measured at the alternator should be 14+V - am I wrong? Just to be certain, I measured the voltage at idle, at 1.5k RPM, at 2k RPM and 2.5k RPM - since the exciter is built in I believe the DB Electrical alternator kick in somewhere in the 1.2k-1.5k RPM. Same results.
The wiring of the new alternator was straightforward given it only uses one wire and it also appears to be well grounded on the bracket.
So, how should I go about troubleshooting? I have been thinking over and over and I cant come to any other conclusion than a bum alternator - which I am a bit concerned about because I ground out some of the housing to fit it in the bracket. Or could i have gotten the wrong alt... like maybe a clockwise rotation unit.
As always - thank you in advance for any help/advice/ideas.
