Originally posted by 32offer
View Post
As far as getting the right motor, based of year of the boat and HP I believe everything past 95 and about 285 HP was roller. It really doesn't matter as either would engine theoretically work but the roller would have the theoretical edge in performance and longevity due to reduced wear in the valve train from the roller technology. This topic is what always has me a bit on concerned when looking at a used boat with a "new" engine, as in "what new engine did they put in?". There are so many low budget or cheap people that will try and save a couple hundred dollars on a $5K build that unless you're really careful you could end up with a low quality new engine from the guy telling you the engine was changed recently.
To me your choice is easy, buy the roller engine and forget about it. Why would you even consider a lesser engine other than possibly needing additional parts for a conversion.
