I have a 2019 Prostar with Ilmor 5.7. 350 hours, never any issues.
The boat is used every week end and for the first time I got a stage1 205 temp warning.
It’s not a sudden temp climb like there is no water flow. The boat runs at 170 for 4 passes at 34 and starts to slowly climb a little bit more each pass after this.
Idling or running at 25mph seems to get the temp down a bit.
Impeller was replaced a few months ago
Strained housing and hoses were checked
Thermostat seems to be working (opens and closes in hot cold water test)
The gasket that sits below the thermostat was chewed though.
At 205 the engine did not smell warm.
Other that this the engine starts and runs great until alarm where it t would go into limp mode.
Any ideas? I am planing to replace thermostat but was thinking it could be a bad temp sensor.
