Yes but those pictures look much worse than the ones you posted up last week. You keep saying "it runs fine", which is what keeps me heading towards the sensor readings. It might be worth buying the MEFIBurn software so you can see what the ECU is seeing and doing, it's great for diagnosing issues (logging, live readouts etc)
I can't remember seeing what sort of use you putting the boat though and whether you've given it a good blat, then turned off and checked the plugs etc, whether you have 20min idle to and from the ski zone or whether you can ski off the dock, all these things need to be considered when inspecting plugs. Are you chugging along fully laden surfing, no/full ballast and boarding or running 26/28/30/32/34/36 mph and course/free skiing - and at which point are you checking the plugs? - everything may be fine but you're just hitting a rich zone in the map - see software!
I don't know how much of the season you've got left, I presume from your header it's just a few weeks, I'd keep banging on with it as is, then whip the injectors out for cleaning and testing over the winter.
Then thoroughly and methodically work through the fuel system, cleaning out EVERYTHING (including the return hose), replace the fuel filters, flush the tank etc, then check the main sensors (MAP/ECT/TPS) to ensure they are within tolerance, then check the resistance / continuity of the loom for those sensors.
