351 exhaust manifolds, 1989 Prostar 190
  • 351 exhaust manifolds, 1989 Prostar 190
    I've got to replace the manifolds and a lot of places are out of stock. I've found a set of Sierra 18-1998-1 which would fit. Has anybody had any experience with these on a Indmar 351?
    Those work just fine. I think Barr makes them with the Sierra stamp as a replacement for the Barr FM-1-83 universal center riser exhaust manifolds. Fit is no problem. If they are available, I would not hesitate to use that issue brand.
    If you can find a kit set, I recommend that kit; includes gasket for the block and the riser and new bolts. I have seen the manifolds mounted without a gasket but I prefer gaskets in that application. Also use anti-seize on the bolts. I have torque specs if you need that data.
    The OEMs with the MC logos are long gone.
    93 190
      perfect thank you
        Curious, what is the cause for manifold replacement on this engine?
          Rust degrades the manifold resulting in water leaking through the manifold. Water can leak externally or more so, undesirably internally to the engine block into the oil.
          Plain old wear and tear from iron oxide hydrate.
          93 190
            Inboard online has them. That’s Indmars online parts company (and they own Barr Marine). Use code IOLROCKS for 10% off.
            Wherever you get them check shipping costs - they are heavy!
            https://inboardonline.com/ford-short...ifold-fm-1-83/
              That link in the post above this post is the way to go (availability and 10% off).
              Get all new plugs, elbows, and bolts. Check back here before you put the new back plugs in. There is a seemingly logical way (not) or an easy way I can share to get it right the first try with no leaks. There is a trick to it. Same with the elbows.
              waterlogged882
              93 190
                There is a water jacket that surrounds the exhaust manifold and the riser, which is mounted to the manifold with a gasket between them. The hot exhaust temps are buffered by the water jacket. Waterlogged's on point as usual: rust will deteriorate them from the inside out. Freshwater inboards can run for years and years. Boats used in salt water usually replace manifolds and risers every 5-7 years b/c the salt destroys the cast iron much quicker than fresh water. I just replaced my riser gaskets as they had a 'small' leak visible by white streaks down the sides of the manifolds. I had a machine shop grind the mating surfaces to remove the pitting that was evident....but I'm saving for replacements next year.
                Here is cutaway of a manifold (from planetnautique):
                  Trouble is that until they actually leak it is almost impossible to know the condition of those inner webs.
                  More commonly the gasket at the top between the upper and lower manifolds leaks and allows water to drip down into the center - but silty crud builds up in there at the bottom and they corrode from within.
                  Probably should be a common thing to remove the inlet hoses and make a pressure washer fitting and while running blow those out with a pressure washer.
                    When I drained the starboard side manifold the other day about a tablespoon of iron came out with the water. Looked just like sand.
                      That is pretty common. As the sand changes to chunks the size of pennys, nickles and quarters you'll know there is serious rust going on.
