I'm looking for ideas:
After a half-day on the water, I've got a bilge so full of water, the bilge pump is running frequently.
so far:
- I dried the boat out completely on the trailer, then filled all of the ballast tanks overfull, then checked for leaks overnight. Bilge was dry.
- I had water coming through the propshaft packing gland, so I spent $1000 having the dealer lift the engine to install a dripless shaft seal - no better.
- I attached a garden hose to the flushpro and ran the engine - no visible leaks.
- At the dock, I've looked for obvious leaks from around the Perfect Pass, the engine raw water intake, and the ballast raw water intake - none visible.
Ideas, anyone?
so far:
Ideas, anyone?
