Hello,
The motor on our boat started dying when in idle. It would only happen when the gas was below 1/2 tank. The motor would always restart after a few seconds and ran strong when under way. From my reading it appeared to be a clogged fuel filter. I am not going to get into the details of the whole fuel filter vs fuel level discussion. Do a search and you will find plenty of reading material.
Although there are many posts about changing the fuel filter, there are no pictures. And a picture is definitely worth a thousand words. So, I took a few pictures a long the way in hopes that it will help those who are wanting to do the same. As I found, it was not entirely as one might think.
So, I ordered a new filter, new seal, and 12 new bolts. MC does not sell just the washers. The part numbers are 155-101 (fuel filter), 155-102 (gasket-fuel), and 155-127 (bolt module). I bought, but did not need, a fuel line removal tool. I was able to remove the fuel pump enough to replace the filter without having to remove the fuel line.
Here is a pic of the tools I needed/supplies I used.
Here is a pic of the fuel pump "module." I had already disconnected the fuel pump wiring harness and disconnected the battery.
