Cleaning up the engine compartment, greasing the steering linkage, checking the shaft packing...
Sodar, not very difficult to do. I began the project thinking I was going to use T bolts but had difficulties locating some and the price was quite high when I did. I ended up using flat head counter sunk style 6MM-1.0 x 30mm SS machine screws and nuts from Lowe's. If you decide to tackle the project, I would suggest putting the whole windshield together and then mount it as one piece on the boat instead of installing one section at a time as I did. I installed the sides of the windshield on the boat first and then slid the middle section in mounting it last. It took some persuasion to get the middle section to slide in. Knowing that it is difficult to obtain replacement glass for a 91, I was uneasy with the persuiasion method. Another tip to make it easier is to use liquid hand soap when installing the glass and gasket back into the frame. It will make it much easier to make adjustments to the gasket so it sits just in the frame just right. I placed the gasket on the glass, rubbed hand soap on the outside of the gasket, and then slid the frame onto the gasket and glass. The soap allowed me to make adjustments to the gasket where it was either pushed into the frame too far or not enough. Another I item I think worth mentioning would be the gasket that sits between the windshield frame and hull. I found the Taylor Made brand on the web and some other brands at a local West Marine. When I looked at it, it seemed to be the same or very similar to the weather stripping you can purchase at your local hardware or big box store but at a much higher price. Having said that, while I was at Lowe's comparing, I found marine & automotive weather seal by MD that worked great, looks good, and seems to be more durable (10 yr warranty). It's rectangular in shape, works like a "D" gasket, comes in 10 ft rolls, and sells for $7 instead of $24. The size I used was 5/16" x19/32". I will try to take some pictures and figure out how to post in the next few days. I’m a newbie to the board.
Originally posted by skierdan View Postcahnged the fuel sending unit so my gas gauge works now. this is a big step for such a noob!
winterized, changed oil and tranny fluid. still cant get the $^&&$% impellar out.
Working on: buying a 97 ps205. Finally found one, attempt #5 for this summer. Hopefully this one works out. I think it's a good deal. Just need some more up close pictures and on-the-water video then I'll send some money to hold the boat before I make the 9hr drive. Should be able to ski into November here in OK so no plans to winterize after I get'er.
Originally posted by holdebt View PostInstalled glass in newly powder coated windshield frame. Drilled the mounting holes out in the frame and on the boat. Then installed windshield back on the boat with SS hardware using bolts instead of screws. Looks so much better and the windshield will no longer bounce.-Aaron
RED 1996 Prostar 205
Indmar 350 TBI
Acme 541
PerfectPass Stargazer Wakeboard Edition
pulled the back firewalls off to find that I have three ballast pumps, with three different part numbers. I have 4 blower ducts, only one of which is connected to a single blower unit, some random wires, and some weird 'tee' plumbing on the starboard side ballast manifold. Thoughts? Or am I just anal?
New LED tail-lights from Harbor Freight: $50.
Removed the welded-on plate for the factory tongue jack, which was broken. The welds on the jack were probably strong enough to hoist the entire rig.
Next: replace the stupid boat restraining bar with a proper winch and winch stand.
