  • I changed the impeller, cut out the bad section on a cooling hose, got my analog speedo working and calibrated my Perfect Pass. My ignition was also a little crooked so I straightened that up as well. I have a little fading on the deck so I got after it with some wet sand paper and rubbing compound which did the trick. I only did a small section before I decided to tackle the whole thing. Looks much better though.
    Next up is changing my speakers and head unit. The current Kenwood unit still works fine, but the speakers are shot and my cover for the head unit no longer stays closed. I would like to put an amp and some speakers on the tower as well, but bc of the low garage door I have on the boat house, I have to remove the top section of the tower every time until I rebuild the boat house with 9' doors.
    I was able to help my bro in law out by doing a little wet sanding and buffing on his boat as well. His has spent most of it's poor life outside uncovered so I thought the gelcoat may be toast but it has really come back to life and now he has it covered. All in all it was a fairly productive weekend though.
    • Oiled the teak platform, yesterday first coat, today second, looks new
      • Originally posted by Quinten View Post
        No picture???
        sigpic
        • Replaced pcv valve
          Washed boat with kaboom shower cleaner and a non scratch sponge
          Crawled under the boat and scrubbed the bottom with kaboom and a non scratch sponge
          Waxed bottom of the boat to keep scum away (no the boat never stays in the water lakes are just real dirty)
          Waxed the rest of the boat
          She's all beautiful now
          Rollin' Gangsta Style
          Originally posted by Thrall
          Originally posted by thatsmrmastercraft
          • I am in the middle of installing a Guest 16102 Battery Charger and a new Clarion CMD6 with a new remote.
            Guest Charger
            -Cameron
            2007 ProStar 197
            1996 ProStar 190
            • I clay bar'd then waxed ALL the fiberglass - under - over and in. Very satisfying when done, but man, what a PAIN. One of those things that half way in you are like "why on earth did I start this???"
              • My 12 year old waxed the boat today. Does that count?
                https://badges.fuelly.com/images/smallsig-us/302328.png
                1988 prostar 190 SOLD
                2001 Prostar 209 SOLD
                • I think you get bonus points!
                  "Mind if I look?" - Kyle
                  • Removed decals and compounded/polished Maristar 225
ID:	2312717Click image for larger version
                    • Renewed the 4160 carburator, runs like new again...
                      /spôrk/
                      • I replaced my fuel pump and filter yesterday. While I was in there I discovered a 7/16" layer of water in the bottom of the tank!
                        So I wired up some extention wires to hook the old pump to the battery, connected a long run of 5/16 fuel line and pumped the tank dry. A guess is I got 2 - 3 gallons of water out. I wiped the inside of the tank as far as I could reach with a rag.
                        The new pump and filter will be starting as fresh as possible now.
                        Jeff
                        • New charger installed.
                          -Cameron
                          2007 ProStar 197
                          1996 ProStar 190
                          • How difficult was your charger install? How long did it take?
                            • Very clean install, Cameron.
                              What products, part numbers did you use?
                              -Tim
                              • Originally posted by MASTIQUE View Post
                                Install was not tough. I hate wires, so the hardest part was routing everything so it was hidden. I used a flexible rod to fish all the wires from my mounting location, under the floor and then to the battery box. All in all, it took probably 3 nights and a 12-pack!
                                Thanks.
                                I bought a Guest 16102. It is a dual bank 12amp (6amp per bank). I then installed a flush receptacle.
                                -Cameron
                                2007 ProStar 197
                                1996 ProStar 190
