  • Installed my new speakers with new speaker wire and put the plugs in where heater fittings were. Took some measurements for fresh air exhaust and muffler delete
    Tapatalk
    • Got the old skid pads off and cleaned the fenders...just followed someone else's suggestion of using wd40 on the glue...spray and wait 10 minutes, then scrape off with a razor blade...easy job.
      • @ Rockman:
        Like the powercoating. I need to do all of mine.
        • Finally got around to getting the insulation installed on the doghouse...scraped all of the old glue off as in the first picture, had one side of the old insulation complete, so I peeled it off to make templates and then installed the new insulation. Now just trim and tape seems and then work on the cut outs for the cup holders and vent.
          • Originally posted by mikeg205 View Post
            Looks awesome... who around here does that?
            Not sure...I sent them out to a place that my wife uses for their display towers.
            • Originally posted by Rockman View Post
              Looks awesome... WD-40 on the adhesive removal on the dog house as well?
                I just used a paint scraper and a small hammer to get under the old adhesive...then just used the paint scraper to get off as much of the old adhesive and foam as I could. I did not spend more than 10 minutes on the cleanup...was gonna sand but then was like..."forget it!"
                • Originally posted by thatsmrmastercraft View Post
                  Care to give a description of this method?
                  1. Using two strong magnets, tape the first one on the inside of the hull where the fittings, elbows, etc have enough clearance to assemble.
                  2. Go under the boat and move the magnet around until it is attracted to the one inside the boat. If location is ok on the underside as well. Mark the spot to drill. I had to go under the boat a few times to adjust locations but worked out perfect.
                  Can't believe someone hadn't thought of this earlier. Wakemakers mentioned it when i was buying the ballast parts and also mentioned the fact that they have a utube video online showing how to do it.
                  • Originally posted by Rossterman View Post
                    What a great simple solution to way too much impossible measuring.
                    sigpic
                    • Put on the new numbers, clay bar'd and polished.
                      Took it out for the season debut.
                      • Bought new prop. It was an agonizing choice - but I am a stickler for customer service.. after reading about props here and other forums and reviews. It came down to the Acme 541 3B or the OJ Force 4B... Great tech reviews on performance vs the 4B Force. But the customer service issue kept on popping every where I looked.
                        So I went with the OJ Force 4B which included a refurbish on my old Legend 3B.
                        Of course will post pictures when it arrives. The information here was stellar - the best of all the other sites I looked at. We'll see how I like it - I can always return it.
                          Why the 4B?
                          My OJ experience sucked. Except for the prop. That is awesome. But they lost a customer here.
                          Sent from my HTC VLE_U using Tapatalk 2
                          sigpic
                          1 Corinthians Chapter 13 - 11
                          • Dam taptalk
                            sigpic
                            • Originally posted by neil.anderson63 View Post
                              Neil how's the water over there?
                              Tapatalk
                                The 541 is THEE prop for your boat and motor setup...hope the 4B will make you happy!
