Originally posted by mikeg205
View Post
sigpic
Email - [email protected]
Originally posted by thatsmrmastercraft View PostLooks great. With the no-slip surface, you wouldn't even have to stop at the dock.....just slow down as you go by. Should be able to stick a landing on that.sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Added dual batteries and a perko switch. Was supposed to come from that factory with dual batteries, but only one got installed for some reason.
pulled out the floor to pull out gas tank and clean. had lots of debris and water in the gas tank.needed to be done after 23 yrs. i believe that was the reason of the bogging down of the engine. also put a new altornator belt on. tomorrow she will get cleaned inside and out as well as new trailer lights. next week when it comes in new disk breaks and new trailer tongue.
Get a nee fuel pickup or fix the one you have with super tacky gasket sealant... dont ask how i know... the black cruds.. lol
Sent from my SM-G930V using Tapatalksigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by MattsCraft View PostNot work on my MC - But added my EOH controller to the T-Reg
Actually now that it is done - Hate the location, hit it with my knee every time I get out of the vehicleNow I will be stuck with two holes in the dash panel, need to figure out a good way to fill them
I did that when I removed the mount for my old phone in my truck. Blends right in.Jeff
Tach not working
been trying to figure out why the tach on my 2000 prostar is not working...set all the way past 6. it seems to want to work as I see a little movement. the hour meter is working. I have checked the distributer and it was corroded so I cleaned. the coil looks good. wondering the knock sensor has anything to do with it? any suggestions? all other gauges work.
Ballast pump issue..digging in
So I was out last weekend.. and realized suddenly that the port and stbd ballast tanks wont fillso I check the breakers behind the back seat on port side, nothing tripped... I know my center ballast is filling so I disconnect it in back, plug it into first the port, then starboard side, proving all pumps are working as they would each turn on with the center tank switch.
I have no lights on my port or stbd fill/empty switches, and no power to pump...
I've read a bit about the black boxes inside the big black box where the breakers are.. anyone have luck replacing those things? wiring in that looks like a pain...
anyone deal with this?
