  • Tph when are you posting the build thread on that
      • Summer Prep
        Replaced one of the ballast pumps on the center tank, and got MC approved for replacement bimini - both under warranty! Nearest dealer in Augusta GA was awesome and made it all happen. Also picked up a new surf sleeve (mine had worn out from the sun) and new surf board. Going to be a great summer!
        • Storage Area
          I still have a few issues to work out. I'll put something up after it's done.
          • So I’m getting the new to me X25 ready for the water and got the FAE installed. Here’s some pics:
            I’ve had an FAE on every inboard I’ve ever owned, but this is the first time I went with the 1 piece pipe, and I really like the look of the Y pipe. I also opted for the trim tab braces as opposed to the swim deck mount. I think it turned out well.
            Those guys at http://freshairexhaust.com do great work. Up for tomorrow, rub rail docking lights & getting started on Clarion —> Fusion upgrade.
            —Sky
            2006 X-1 Pumpkin Orange SOLD
            • Looks great! I've been toying with this as well, and really like the Y versus the T style. Would love to know your thoughts after you test it out.
              • Getting it ready to have the interior replaced!
                • Repairing the keel . Erased, sand, hard mooring nose. I use gelcoat brush application of 5 -7 layers.Then sanding and polishing.
                  • Ok, beautiful weather in the PacNW today, so a lot happened.
                    First, I installed a custom dome light. I couldn’t really tell how bright it will be (full daylight), but it is 2ea 3W LEDs, so it should do well. The button in the center turns them on and off. I have 2 more of the LEDs if I need to add more light. Here’s a link to the LED bolts I used (3W Stainless): https://www.oznium.com/led-bolts-prewired-leds/led-bolt
                    I really like how you don’t even notice them unless you know they are there, and I wired the switch light to be on whenever the battery switch is on, so it’s easy to find in the dark.
                    Since I pulled the Tower Speakers and their forward facing lights, I wanted something for docking, so...
                    As I mentioned, I pulled the 4 stock Mastercraft Speakers, and replaced them with Roswell R1 Pro Tower speakers. Special thanks to Roswell and Wakemakers for getting me a pair with Mastercraft Tower clamps. As far as I know, mine is the only Mastercraft with these mounted. They sound and look great. We’ll see how the plastic holds up. Looking at these pics, I should have taken some without the LEDs on to show that he areas that are showing up as blue are white when the LEDs are off (or in broad daylight where the LEDs can’t overpower the sun). Sorry that some of these pics are sideways, I hate it when TT does that.
                    But wait, I got more done. It’ll go into the next post.
                    —Sky
                    • To drive those Roswells, I replaced the stock Clarion with a Fusion Apollo system:
                      I wanted something lower profile (and cheaper to replace if it got hit by a wayward wakeboard) so I went with the Fusion wireless remote on the stern. I’m manufacturing an ABS bezel that will cover the screw holes on either side of the remote.
                      Although the carpet is in pretty good shape, I’m a big fan of Deckadence, so I pulled the carpet out and laid out what I ordered from Jim’s Marine Flooring. He did a great job cutting it from his pattern.
                      And finally, I added a HangTyte anti-pooling device to my cover. Every boat I’ve ever owned that had a tower has had one of these. Water never pools on the cover, and living in the Seattle area where liquid sunshine is a real thing, keeping pools off your cover keeps the interior much nicer.
                      I also sprayed the cover with Rustoleum Never Wet, but no pics of that.
                      All I have left on my list is getting the firmware on my 7” Murphy screen updated (some of you may have noticed that I was trying to update it when I took pics of the Deckadence), getting the bezel for the stern wrapped up, getting my DomedNumbers installed and cleaning/waxing it before it goes in the water. As a side note, does anyone have any great ideas for temporarily applying numbers while I wait for DomedNumbers? I’ve got another month before they get here.
                      It’s getting close!
                      • Installed new Fulton 2 speed 3200lb winch and Boat Buckles on the trailer . YAAAAAAA....
                        • I temporarily put them on the lower side of the wrap-around windshield and taped the renewal sticker to the inside of the glass to use on the hull when I get my domed numbers. A little tackey but legal for now
                          Our 2014 X2 is Sold.
                          • Originally posted by skydyvyr View Post
                            [ATTACH]195359[/ATTACH]
                            [ATTACH]195360[/ATTACH]
                            [ATTACH]195361[/ATTACH]
                            [ATTACH]195362[/ATTACH]
                            [ATTACH]195363[/ATTACH]
                            [ATTACH]195364[/ATTACH]
                            [ATTACH]195365[/ATTACH]
                            [ATTACH]195366[/ATTACH]
                            —Sky
                            Where did you get the switch? Was the switched power wire in the tower already, it did you have to run it up?
                            • Originally posted by bcd View Post
                              The wiring harness in the tower already had power. In the center box at the top of the tower there were four circuits, one labeled for the anchor light, one for white dome lights, one for rear facing lights and one for red dome lights. The red dome light is live whenever the battery switch is on. I got the button on Amazon, here is a link:
                              https://www.amazon.com/dp/B07P9X7BR1...roduct_details
                              It looks like the icons on the buttons have changed, but you may be happy with one of the ones they offer, or may be able to reach out to them to request one you do like.
                              —Sky
                              • Fun stuff
                                Did new risers and manifolds on my 351. Skidim deal on both. The manifolds (Barr) fit a little closer to the engine but its ok. Just make sure you take advantage of the manifolds being off and replacing the valve cover gaskets. Everything else was good. Did I have to replace them? After seeing what they looked like after 27 years maybe not. I suppose I could have had them boiled in a tank but nobody has acid tanks anymore. Remember when you could take an old rusty part to Napa and they had a hub store somewhere with an acid tank for heads and all that stuff? They were actually in pretty good shape. Did an axle and disc brake conversion too. Just need good weather now. Ran a compression check and couldn't be happier.
