Originally posted by waterlogged882 View PostI see a new OJ shaft log seal. Nice.
Prostar205
"Did you're flex plate fail or preventative winter maintenance? New one looks nice."
No I just thought it was about time almost 1000 hours on it. I have owned it since 280 hours.
todays job clean the trans mounts up so the alignment goes smooth and stuffed the trans back in.
Still some more work to do. I tend to clean more than reinstall.
99 MariStar 230 Sport LTR 330
- Likes 1
Removed the hard tanks.. 2008 X14 Hard Tank Removal - TeamTalk (mastercraft.com)If its not a competition ski boat, its always second best.
- Likes 1
It's been a few weeks in the making. I decided that having a FAE (fresh air exhaust) negated the need for a space consuming and frustration inducing muffler. I got ahold of the good folks at FAE and had them build me some straight pipes with baffles in them. They said the baffles weren't necessary unless I didn't have a FAE or exhaust flaps. I saw a Malibu last summer lose its FAE so I decided to add baffles "just in case."
It's ridiculous how much space I have back there now. I can't wait to change my raw water impeller. I imagine it will be just like heaven.
Removing and installing was a bit of a trick. Some silicone spray and a plastic automotive trim removal tool really helped move things along (no pun intended).
4 Photos2004 X-30 5.7L MCX
- Likes 2
Completed so far this winter:
New faria gauges
New fuel level sending unit
New engine water temp sensor
New depth finder and transducer
New rear port and starboard ballast pumps (upgraded to the ballast kings in lieu of the puppies)
New ballast intake assembly
Replumbed all the ballast to 1" hose
Changed rear tank fittings to 1" (originally 3/4")
New 5 channel fusion amp
New (used) wetsounds tower speakers
Rewired the tower (new wires and connections)
New zone control for audio (cabin, speaker, sub)
LED bulbs in Tower Lights
New fire extinguisher
New fuel pump gasket
New horn
Still on this year's list:
New interior (headed to Viper 4/7)
New flooring
Adjust shifter
Service Trailer brakes (flush break system)
Service trailer bearings and seals - Lucas hub oil
Wax boat
Treat cover
Replace keel roller and 5/8 rod
Oil Platform
Remaining Items on the Master Plan (for another year):
Strip and replace decals
Sand and buff boat
Install New lettering/decals
Make new Platform Cover
Remove Carpet
Install Deckadence
Replace brake actuator
Replace heater core
Replace subwoofer
Repair bimini
Fresh Air Exhaust
POR 15 (or similar) the interior of the trailer tube steel
- Likes 2
Got a new fire extinguisher and got the boat certified for the next year!2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier
I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula:
Originally posted by lakedrum03 View PostCompleted so far this winter:
New faria gauges
New horn
New flooring
Adjust shifter
Wax boat
Treat cover
Oil Platform
Sand and buff boat
Remove Carpet
Install Deckadence
Replace heater core
Replace subwoofer
Repair bimini
Fresh Air Exhaust
Behold, the new gauges.
Thanks Lake, you da man!
15%'er
- Likes 2
Originally posted by CantRepeat View Post
Tell me more about that lathe please!!!
E: e type spindle with 4 steps on v-belt drive
S: 11" swing
W: clutched apron for power feed on cross slide and carriage
Q: quick change feed box
That's a Sheldon ESWQ with a 56" bed. I inherited it from my uncle. We had to pull it out of his basement.
S: 11" swing
My needs are basic but I have dreams about having phase 3 power in my shop and it's filled with metal tools!-Tim
Making boomers great again!!Boomin'
