Oh no. I am thinking of doing this but that is one fear I have.
Originally posted by J NORRIS View Postresearching drivetrain alignment, here on the site. Finding good instructions on shaft alignment. Seems like I need to align everything up after a submerged log hit. maybe a new strut!? Can those things be straightened with a rubber mallet? If so, does it damage the integrity of the metal?
I have a 2010 X55 and when I do anything in the engine bay, I have to remove the StarBoard dividers that separate the lockers from the engine. This involves screws and Nyloc nuts with washers that always tend to fall and land under the engine. Enough was enough, I ordered some compression latches and installed them into the StarBoard dividers. Now, when I need to service something, removing the panels doesn't even require a tool. And since I was making my life easier, I relocated my oil filter. No more standing on my head to do an oil change.
3 Photos2010 X55, 8.1L
👍 2
Originally posted by jnb0y View PostI have a 2010 X55 and when I do anything in the engine bay, I have to remove the StarBoard dividers that separate the lockers from the engine. This involves screws and Nyloc nuts with washers that always tend to fall and land under the engine. Enough was enough, I ordered some compression latches and installed them into the StarBoard dividers. Now, when I need to service something, removing the panels doesn't even require a tool. And since I was making my life easier, I relocated my oil filter. No more standing on my head to do an oil change.
Originally posted by prostar205 View Post
Can I get more information on the oil filter relocation kit you used? I see you have the L-18 engine in your X55. I have the same engine in my X30 and can complete relate to your comment regarding the circus act that needs to be done to get the filter off. Also the mess that is makes in the bilge trying to maneuver the filter around the trans cooler lines.4 Photos2010 X55, 8.1L
👍 1
Yea, the original filter location is miserable. I did my first oil change on this boat and swore the next one would be to install a remote kit. I got the spin on adapter (PN 15705) and remote mount (PN 25709) from Derale Performance. They sell a complete kit with hose and fittings, but I ended up sourcing my own parts locally. The lifting hook on the front starboard side of the engine already has the holes that perfectly match the pattern on the remote mount. I had to bend the dip stick tube slightly back so it was on the aft side of that lifting hook to avoid a conflict with the new filter location. The filter mount uses a different filter than the L18 engine. You will switch to a Fram PH8A / HP1 filter form after you install the remote filter mount. Once you get the original filter off you just assemble the spin on adapter and spin it into place where the original filter came out. To make sure you get the oil in and out ports straight I recommend marking them with a Sharpie on both sides of the adapter before you install it. There are marks on the adapter but they won't be visible once it is installed on the engine block. After that just attach the lines and route them up to the remote filter mount. Just make sure you keep the oil flow correct between the adapters (out of spin on adapter, in to remote filter mount; out of remote filter mount, in to spin on adapter). If you cross those lines you will have big trouble.
Another question/observation - do you not have a fuel return line back to your fuel pump? My 2002 L-18 has a return. Also, is that a strainer in picture 3 and 4 for your incoming raw water?2002, X30, L-18, Red Metal Flake (the possessed boat)
Thanks for the pictures.
Another question/observation - do you not have a fuel return line back to your fuel pump? My 2002 L-18 has a return. Also, is that a strainer in picture 3 and 4 for your incoming raw water?2010 X55, 8.1L
👍 1
I think in 2003, 4 or 5 they switched to a returnless fuel system on the 8.1. The pump is variable speed or there is a pressure bypass in the tank. I don't know how Indmar does it but this is what I've heard about the 8.1L in trucks and RVs. Yes, that is a raw water strainer. I think its original equipment.2002, X30, L-18, Red Metal Flake (the possessed boat)
Originally posted by RxMC View Post
How come you're changing that? Just curious.1 Photo
Originally posted by Prostar 190 View PostThe interior was starting to get a little hard so we had it redone. Put it back to factory interior except the front bow seat embroidery I wasn't a fan of the MC half star logo.If its not a competition ski boat, its always second best.
👍 1
