installed LED lighting over 15" KicKer sub
Originally posted by gweaver View PostBroke off the alternator mounting bolt. Not much else to say about that one. Grrrrr.CUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
Seized drain plug on starboard exhaust manifold is turning into quite a little project.
Good thing I have all winter.
Making progress.
After EZ-Out failed to work and got stuck, pulled manifold last night, thankfully went very easy.
Off to machine shop to get it drilled out and re tapped, I think.
edit: the ezout looks funny and angled because it's flopping around in hole. It was straight and true while working on it. After no dice with 1/2 breaker bar, a 1/2 impact gun caused it to thread in and spin.Last edited by Lumbergh; 10-20-2011, 01:51 PM.1991 ProStar / 351W with 1:1 Velvet Drive
My knock sensor would not go back in, after pulling it the first winter I had it - it appeared that the PO had not put it back in correctly, threads on the bolt were pretty messed up. Fortunately I was able to rethread it sufficiently with a dye.
This year, I left it in place, and ran antifreeze through instead of draining.
Originally posted by Footin View PostI had problems with mine last year. I was able to chase the threads then I installed 1/4 turn valves in them, no more pulling a plug for winter._________________
2000 SD prostar 205
I pulled it out of the driveway and put it in the street so I could change the oil in my truck............then put it back where it was. Dang exciting.CUSTOM WHEEL & TIRE PACKAGES
sigpic
winterized....opened thermostat housing for new t-stat...sprayed simple green in entire bilge floor...and wiped it up...looks like new...brushed anti-sieze on water plugs, knock center threads and petcock threads to keep corrosion down...next up good vacuumming....sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
