Has any one ever had a Centerbalast tank Crack on mastercraft?? if soo any ideas on how to patch it? fiberglass did not hold. its a hair line crack at the top seem
Crack in Center ballast Tank.
it is a poly tank, i tried to patch it with Fiber Glass Resin/ fiberglass sheets. about 3 layers thick. it held to the tank bu amazingly the water flows under the glass and out some how. so silly puddy im not so sure will do the trick but i could try it. i also was told to try water weld (JB weld_) but im not so sure that will stick polly either.
Warranty? Have you called MC dealer? They may have some way to do it without splitting the tub out of the boat.
Be more specific on how/why it cracked. I figured they'd be indestructible unless not winterized with a bunch of water left in.'06 X2 MCX
The site below is something I used to repair my rv tanks and has worked well. If you have a crack you will need to drill a hole at each end of the crack or it will continue to crack after the repar.
http://www.shoprvparts.com/product.do?no=12573F99 MariStar 230 Sport LTR 330
I just ordered that Plastic Tank & Radiator repair kit hopefully that works, i will try it out when the weather starts to warm up which is hopefully in a couple weeks.
- I did end up scuffing up the tank around the crack and trying Water weld (JB weld) that also did not work IT it held on the tank great and hardend like steel but some how the water cracked right through it with in two fills of that tank.
i dont understand how there could be that much water pressure inside the balast tank.
AS for how the tank cracked. i have no idea, im clueless. there was never water left in the tank. and there is never any weight on the tank. as for warrenty i dont believe i have one i bought the boat used. last year. and the boat is a 2007.
im thinking the tank was origionally deffective though. but i will try the Plastic tank repair kit. i hope it works
I have used the plastic tank repair on my rv holding tank too and it has been good for about 4 years now.
I have a buudy with a 07 X15 that had the same problem but his was under warrenty. It got sent back to the factory to fix becaue they had to split the boat in two to get it out. Good luck getting something to work because i would guess it's not cheap to have it replaced.
Thanks,
yeah when the weather warms up im going to try my best to seal it with the plastic tank repair.
its in such a bad spot too, the crack is on a corner and on the edge of the top and side. so its right in the seem.. the only good thing is that its pretty ez to get too right through the Center Drain access opening.
If this Plastic Tank repair kit doesnt work.. im not sure what the next step will be... maybe ten rolls of Ducktape and ill just go to town on it. haha
i will keep you posted on how it works out. and ill tyr and get pics too
Thanks
yeah when i get the plastic repair i will try that.
when i first tried to fix it i used fiber glass resin and fiberglass sheets. i made it about 4 inches wider than the actualy hairline crack. but the fiber glass did not hold to the poly tank and the water blew it off. but ill try that same idea but with the plastic repair kit.
thanks
Originally posted by mtajpa View PostThe site below is something I used to repair my rv tanks and has worked well. If you have a crack you will need to drill a hole at each end of the crack or it will continue to crack after the repar.
