X25 cockpit drain
  • X25 cockpit drain
    Any of you X25 owners out there have an issue with your cockpit not draining when the boat is on the trailer or floating at the dock.? It will drain once I get up on plane,u but kind of a pain. See pic..
    Captain Dustin Beatty
    Marco Island, Florida
    www.WakeboardFL.com
    2011 X25 Power Tower Ilmor
    2007 CSX 220ss MCX Ballast,Tower Pkg.
    1992 PS190 351 w/ 1:1
    sigpic
    Uh why is there that much water in there to start with?
    _______________________________________
    X-80 Black/White
      I'd guess dunking the bow
        WOW... no way at all that would be acceptable especially with carpet..
          Filled it up with a fly high pump for illustration purposes. Kinda annoys me..
          Although my son had fun with his toy boat I checked the one way valve and it was clean and clear. Possibly a poor design.
          I am here: http://tapatalk.com/map.php?1zko4o
          www.WakeboardFL.com
          sigpic
            The water should just drain into the bilge area. I have used a hose to wash down the interior floor and it always just drained for me.
            Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. c/w 1/9 scale R/C PWT X-Star
            Owned:
            2012 X25
            2011 X25
            2009 Moomba LSV
            2009 Moomba Outback V
            2008 Monterey FS180
            Pelican 4 set paddle boat
            plastic tug boat when I was 4
              Nope. It drains out of the boat via transom, mid way of the hose is a one/way valve that directed all over the place dodging the bell housing and motor mounts. I wish there where a cleaner path , o well. Really is the only flaw I found with the boat at 200hrs.
              Minus the ZFT4 don't get me started in the thing, huge waste of money. Works maybe 5% of the time.. If you order a boat go with the new ZFT2 . I think that's the new swoop style with Manual levers..
              I am here: http://tapatalk.com/map.php?s0dpx5
              www.WakeboardFL.com
              sigpic
                This makes no sense, that drain should go directly into the bilge!
                  Do you mean go with the ZFT4 vs. the ZFT5 power tower? The ZFT4 has the swoop with the manual levers. I like mine alot.
                    Yes ZFT4.
                    www.WakeboardFL.com
                    sigpic
                      Yes ZFT4.
                      What problems are you having with your ZFT5P?
                      Owned:
                      2012 X25
                      2011 X25
                      2009 Moomba LSV
                      2008 Monterey FS180
                        Salt Water Series X-25s have self bailing cockpits. All others bail into the bilge. You do not want salt water pouring all over your transmission and fuel pump.
                          Limit switch, broken spring, bad actuator , let's see what else. Works 50% of the time....
                          www.WakeboardFL.com
                          sigpic
