Hi guys my 87 prostar 190 has a bad leak where the drive shaft log penetrates the hull. Any ideas on how to repair? Has anyone run in to this problem before?
Drive shaft log leaking help!!
Well, the normal path for water into the boat there is through the packing around the driveshaft, inside the big-ole brass nut just below and out of your picture. That's a normal maintenance item and easily adjusted. Are you sure the water isn't coming in there?
If it's actually coming through some kind of break in the fiberglass, I can't help you. You'll probably have to get someone knowledgeable to decide if the crack is a structural problem, or something simple that a patch of fiberglass and a spot of resin will take care of.
So, I guess, the first problem is finding exactly where the water is coming in.1998 Maristar 200VRS
+1 on Frank's comment.... a video or more specifics where the water is coming in. If it's a bad shaft log it can be replaced. It could be as simple as needing new shaft packing... where is the water intrusion originating? - some water is normal... a few drips per every 10 seconds ok. or you can get a dripless packing.sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
The water is coming in through the fiberglass. I'm very familiar with replacing shaft packing but unfortunately that's not the issue on this one. The boat is at creative fiberglass now (a local shop) and will be ready next week. I'm not a fiberglass guy and figured I would leave it to a skilled hand because we are looking to start skiing in the next couple weeks. I will post pics of the repair when I get it back. Thanks guys!
What's up mike!? Haven't heard from ya in a while.. The repair is gonna hit me for 250.00 and that was a big deciding factor for me because I'm currently out of epoxy resin and mat so I would've had a good bit in materials if I bought the west system stuff because they are very proud of it u know. So he says I should have the boat back next week and I will post the repair pics.kinda wish he would send me some progress pics.
Originally posted by reftech View PostWhat's up mike!? Haven't heard from ya in a while.. The repair is gonna hit me for 250.00 and that was a big deciding factor for me because I'm currently out of epoxy resin and mat so I would've had a good bit in materials if I bought the west system stuff because they are very proud of it u know. So he says I should have the boat back next week and I will post the repair pics.kinda wish he would send me some progress pics.CUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
Originally posted by tph View PostLooks identical to my '89. In my case the solution was to remove all the glass on top of the shaft log, reattach the log to the hull with epoxy and glass over the whole assembly. Took 4 -6 hours and it's been working great for several years.
I should replace my shaft log, it's been there since new and while I'm at it might pull the shaft and replace cutlass bearing too.
Originally posted by d2jp View PostMy '89 is doing the same thing, I bought the West Systems materials this summer but never got around to fixing it.
Ok so my OCD was getting to me and I picked the boat up at the fiberglass shop yesterday. After all I've done to the boats I've restored it made no sense to let somebody else make this repair. I got started on it today and will post pics of my progress. I got the log cut out and all old fiberglass removed. I cleaned the surrounding area really well and have the log epoxied back in. I will lay the fiberglass mat tomorrow. All is going well!!
