I am in the process of getting the tank out to access and hopefully repair the fuel sending unit and discovered a fuel filter of which I was previously unaware. I purchased the boat last fall. It is a '97 PS 190.
There is a grey tube leading from the fuel filter straight down in front of the tank, so it looks like I will need to disconnect this tube from the filter to be able to slide the tank out.
Is there pressure in this line? Will there be a lot of gas spillage that I need to consider?
