Wondering if anyone on here has ever gone about building their own boat lift guides and what hardware they used for it. I have a pretty good idea of what i'm going to do but not sure what hardware i should use to attach it to the lift. Anyone have any suggestions?
Anyone ever build their own boat lift guides?
I used threaded flanges sandwiched around a crossmember. I then used 1 1/2" x 36" threaded pipe as the rigid support, and then a 2" x 42" PVC grey pipe (conduit) over the top of it for aesthetics and keeping the boat from scratching.
the pink stuff is just a gasket so the galvanized flange wouldn't react with the aluminum lift.....starting to look crappy. Need to get a new one.
Works great.
I put some guides together with PVC pipe. Pretty simple construction and they've handled the job well for the last 6 or 8 years. The PVC flexes a bit to help center the boat and avoids scratches on the hull. I'll be headed up north later this week and get some photos posted up here for you.1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition (SOLD!)
The world is full of youth—what we need is a fountain of smart!
Originally posted by JohnnyB View PostAny home built bow stops out there??
Originally posted by Laurel_Lake_Skier View PostI put some guides together with PVC pipe. Pretty simple construction and they've handled the job well for the last 6 or 8 years. The PVC flexes a bit to help center the boat and avoids scratches on the hull. I'll be headed up north later this week and get some photos posted up here for you.1996 FlightCraft Barefooter—Merc 200 EFI
#threadresurrection
These are pretty cool. My lift cross members have a slightly different style but I think that osmonet's approach would work, with some modification, on mine. The ones you buy online retail for $50-60/pair. nuts!boats rock, but don't rock the boat
i'll take a shot at what i did later because i started hating replacing the foam every year. I used a rope and wrapped them first then i used fire hose to stop chafing that the local fire dept was getting rid of over the top. are they the prettiest, no. do they work better than anything else i've found, 110%.
