It wasn't too bad. Kind of a pain for one person due to a lot of getting into and out of the boat, but the install itself was easy and very straightforward.
I elected to NOT switch to the new tiller arm. They are basically the same, and the lever arm is the same between the two, so there should be no handling difference from the old to the new tiller. Plus, I note that the older tiller has an extra hole about 1/2 inch closer, which would increase steering response (at the expense of steering effort) if I ever chose to use that inner hole.
