Hello,
I have a 2018 X23 that I've only had out a few times so far and I add gas manually with a siphon from a 25L (6.6g) gas can. Filling the tank today (from 68% full according to the gauge), the tank started to overflow which I assumed meant the tank was full, but when turning the key on, the fuel gauge only showed 82% full. I have the fuel management feature disabled.
Is it possible that too much air got into the tank via the siphon and it's messing up the fuel reading? I added roughly 80L (21g) of fuel before I got some gas overflow and I'm pretty sure I had more than half a tank of gas left (the 68% reading seemed about right), so I'd expect the fuel gauge to read closer to the mid to high 90's or even 100% full.
Is there something I should check? When I look in the gas fill hole on both sides of the boat, I can clearly see fuel.
Thanks
Thanks
