Hi, So i have a 2001 x star 330 hp. It has the Heater Craft low idle Wye valve installed correctly. Every once in a while the small hole in the y valve gets clogged from shale or what knot and stops proper flow.
I've noticed that other new heaters are much warmer at all speeds. I assume that this is because of the inline pump used on the newer boats has much better flow.
My question is, Can I install a new pump and continue to use the Wye valve or do i need to reroute the return line.
If so I would think I will need to drill out the small 1/8 inch hole in the return line to something bigger. anyone ever do this mod?
