Disassembly of airguides...stuck bezels
  • Disassembly of airguides...stuck bezels
    Bezel stuck...one slid off with lots of pulling....the other isn't budging. Any ideas?
    Sent from my SM-G960U1 using Tapatalk
    2004 Prostar 197, ACME 843
    Just work it with a hammer and a small screwdriver.. i had same issue... it needs to be tapped off little by little
      If that doesn't work..... bigger hammer.
      93 190
        Just tried to lightly clamp it in a vice but that didn't hold.....what did you use to hold it while you tapped [emoji34]
          I just repaired a glass in mine. Heated the bezel with a heat gun slowly to allow expansion of the metal then pulled off with leather gloves. Hot hot hot.
          Our 2014 X2 is Sold.
            Used my hands to hold assembly. Was gentle at first then gave it the taps a bit of tough love. It was a pain between taps... hopefully bezel was not removed then add with some adhesive.
              That worked. All 3 bezels off. One lens casualty. Sciensetuff.com has lenses. Now to drill a hole in the glass....
