So I finished my 1st draft of the bow vent for my 81 with solid works. The bed on my printer isn’t big enough (10.5x10.5) to lay flat and has the vent positioned at an angle on the Z axis to accommodate the first print. Due to this the build time is 1day 14 hours…. there are a lot of supports needed due to the angle and probably the biggest contributor to the build time.
if this even finishes I will be surprised
so I’m probably going to print this in two separate prints once I find a way to hide the joint that looks acceptable. I’m going to work on the other two vents (engine box, rear vent) which should fit on the bed.
