Question for those who have installed SeaDek or similar product
  • Question for those who have installed SeaDek or similar product
    So how clean is clean enough on prepping the surface? I'm replacing my trailer step pads with a custom SeaDek set and am having a difficult time getting the last bit of adhesive residue off from the old pads. Is there any margin of error here, or do I need to keep at it? I've been using Goo Gone and Acetone along with a plastic razor blade scrape tool, but have kind of hit a wall. There's a few rough spots, but for the most part fairly smooth and clean. Here's a couple pics. Appreciate any insight or guidance from those who've tackled this. TIA.
    ¡Viva 205V!
    2003 X2 MCX
    I installed HydraDeck on the bumpy surfaces by my feet and where I step in my boat. I was concerned it wouldn’t stick. But no issue.
      I did this exact same thing to my trailer and ran into this exact problem. I just went ahead and put the pads on and have had no issues
      -Tolman
      '22 XT23 "Big Kahuna"
      '06 X30 (Sold)
        Thanks for the replies. So based on what you see above, you think I’m probably good to go once it warms up? I’m going to risk scratches if I keep at it.
        Did you use 3M Primer 94 on yours? SeaDek lists it as an ‘optional’ step.
        ¡Viva 205V!
        2003 X2 MCX
          I use 3m adhesive remover, low temp heat gun, plastic razor blade to remove old glue. Yes I would use the primer. Not necessary but it definitely helps keep it stuck on.
            I think your good to slap them on. I didn't use primer and they have been fine for the 2 years I've had them. Best of luck, your boat is really becoming something special!
            -Tolman
            '06 X30 (Sold)
