Hello guys I am going to making own thread for the boat restoration project I am doing. I know I will have alot of questions and replys to this post. I have the other post and pics on Winter projects. Thanks guys for the info I have gotten so far about the boat. There will be more pics to come.
LTD Mastercraft restoration
Beer bottle brown metal flake is my most favorite color
(hope you can sand that back to it's former glory...)http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
Just be careful when sanding. You sound like you have some experience in mechanicing, I just want to put my 2 cents in that you would be surprised how well you can get that gell coat to look if you take your time sanding through the wear and tear. Of course it is sometimes much tougher to bring the metal flake back our to look good than bringing out standard gel-coat colors. Good luck. The more pics you post, the better for everyone. I love seeing someone else project in motion. If I was up there where you live, I would be outside with you sanding away.
Originally posted by americanskierJim View PostHello guys I am going to making own thread for the boat restoration project I am doing. I know I will have alot of questions and replys to this post. I have the other post and pics on Winter projects. Thanks guys for the info I have gotten so far about the boat. There will be more pics to come.Automatic doors make me feel like a Jedi
Thanks markismm, I could use another hand with the sanding. Here at my body shop I can get one other guy to help out with the sanding. It will take sometime to sand I am ready for the challenge at hand to bring it back to life.
Yellow78mc, Thanks cant wait to get them on the boat but it is going to be sometime before they get put on.
I will get some pics of the motor tomorrow. It is all all done but the carb (600 holly)has not been put on as of yet. I painted the block Blue and the heads are black there new heads. the pully,s are painted chrome for now untill I want to get the real thing lol. I laso added a breakerless system so no more points to deal with. new cap and wires(not on yet).
Originally posted by americanskierJim View PostHere is a pic of the manifolds I am going to blast them tomorrow so I can repaint them. I am going to do the lettering in white and try and do the "V8" box in red with the V AND THE 8 done in white.
Originally posted by americanskierJim View PostHere is a pic of the manifolds I am going to blast them tomorrow so I can repaint them. I am going to do the lettering in white and try and do the "V8" box in red with the V AND THE 8 done in white.http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
That is what I did on my manifolds. I painted the non-water-jacketed portion of the manifolds with a high heat 550deg paint and the rest of the manifolds are painted with a 350deg wrinkle paint to change up the factory look. I am not a big fan of the gloss paint put on from the factory. In any event, I would definitely paint the runners with as high of a temp you can find or it will burn off and rust in the same place yours already have. Can't wait to see how they look when finished.
TMCNO1, Thanks for the info I have a been looking at DIM book to get some new ones. I will get them apart and get them cleaned up and resealed. I also need to get a new damper plate the old one is a bad one.
JLeuck64, I do have 1500 paint I would hope that it doesnt burn off.
Markismm, I like the way you did yours I will keep all your tips in mind when I do these manifolds. Shouldnt be to hard to do.Last edited by americanskierJim; 12-21-2009, 10:12 PM.
