90's Tristar into outboard-MC Prototype? Restoration
  • 90's Tristar into outboard-MC Prototype? Restoration
    So, according to the guy who sold this to me in AZ this was a mastercraft prototype before he had it. I never confirmed this, but it does not have any holes for prop or rudder in the hull, no supports for an inboard engine. It appears to be a tristar conversion. When I purchased it the poorly welded jack box sitting on top of the swim step had failed and all that was left was some shredded outboard connections. I picked up a 1990 Yamaha 250 in Louisiana on my way back to PA.
    Here is where I am at so far.
    Had the jack plate re-welded and strengthened, and then I drilled and bolted it at all critical spots so that will not fail again.
    Mounted the 250 on the back, installed the controls and took it for a test run.
    It was very tail heavy and drove like a drift car/jet boat - (didn't turn until the prop overcame the turned hull.)
    SO
    I have welded up a frame between the stringers and installed two tracking fins in similar fashion to my ski centurion barefoot warrior outboard- roughly 2/5ths forward from the back.
    Once the 3M sealer is cured I will be taking it for another test run, and bringing 5 gallon buckets of water to place in the nose. I plan on testing it with various weights in the front to find the optimum balance and then installing ballast tanks in the front for the future.
    ? Does anyone have suggestions on best method of filling/draining ballast tanks? I have several different tanks from old campers that I can use, just need to set up pumps or intakes or whatever.
    ? Anyone had a similar set up? I am wondering if this will allow me to turn and control well enough or if I will need to install an actual rudder like an inboard as well? (not sure how I would combine that with the hydrolic steering)
    Questions? ask away, I will try to post pics later.
    Who reads posts? I just look at the pictures.
    I think pics are necessary on this one?
      ^^^^^^^^This
      sigpic
        bump for pics
          sigpic
            bump hhh
            sigpic
