Hi, been reading TT for awhile now and stealing lots of good info from it. I've been working on doing some deferred maintenance on the boat, so I've been looking at a lot of more random parts. I thought I would post all of my research/parts list in one spot for those that might be in a similar situation. After all, these boats aren't getting any younger. Hopefully this is helpful to someone.
In general, I use a 1992 Corvette 5.7L OHV (P engine code in VIN) to find similar parts for the LT-1. So far, it's worked pretty well.
I also have a MC single axle trailer that I've done the UFP drum to disc brake conversion on. Trailer details are as follows:
And finally, I haven't tackled this yet, but plan to, so here's the info I've collected on changing out the carpet:
If you've got anything to add that I haven't covered, let me know. I know about the CPS thread, but haven't gotten around to adding that info yet. Also, if anyone knows where to get the service manual for the LT-1, please chime in.
- Oil Type – 4-5 qt Marine 15w40 or SAF 20-50
- Oil Filter – Napa Gold 1069; WiX 51069; K&N HP2002; AC Delco PF454 (PF25); Mobile M-1 302; Penzoil PZ-3; Purolater PureOne PL34631, PL20049; Bosch 3510 (tall)
- Spark Plugs – AC Delco MR43LTS (0.045” gap)
- Impeller – Indmar S685007 or 685007; Johnson 09-812B[-1]
- Thermostats (2 required) – 160°F w/weep hole (top of circulating pump) and 143°F (in triangle)
- Water Circulating Pump – GM 10128327 (casting); AC Delco 251-537 (temp?), 251-554 (heater hose); GMB 130-6073; Master Pro 58-445; Cardone 55-13815 (new), 58-445 (reman); Tru-Flow TFW 44035; Napa WP58445; Duralast DWP-9000; Murray CP5063; Gates 44035; Bosch 99149 (no temp sensor hole)
- Belt – Indmar 72-5010, Gates Micro-V K060390/6PK0990 (39”/990mm, 6 groove)
- MAP Sensor – GM 466 (1 bar), Delphi PS10075
- Fuel System Info- Fuel Pump – Carter P60962 (37GPH, 120 PSI max), Indmar 556014
- Fuel Filter (Main) – Napa FIL 3481, AC Delco 89058397, Wix 33481, Purolator F33144
- Fuel Filter (Inline) – FIL 3482, AC Delco 25171391, GM 25055066, Wix 33003 (clear), Wix 33033 (metal), Wix 33482, Purolator F21111
- Fuel Pressure – 40 PSI
- Fuel Tank – Moeller FT3112 (safe for EtOH)
- Fuel Pickups (In Tank) – Walbro MP (Orig), now Walbro MP-12 and MP-16 (physical size and hose connectors are different, but work)
- Fuel Pickups (Tubes) – Moeller ¼” NPT Aluminum Withdrawl (033500-12 - 12” length, ⅜” NPT mount, ⅜” hose); can get 033500-24 for 24” hose
- Tank Pickup/Sender Plate – No longer made
- Fuel Lines
* Tank to pump/return: 2x10’ ⅜” A1-15 hose (Orig = Moeller 034314LP; Trident 365; Shields 365/368; MPI 350; Novaflex 360-0-9)
* Filter to Block – ⅜” hard line w/16mm nut (Dorman 800-170) + 1’ ⅜” A1-15 hose + ⅜” GM Quick Connect (Dorman 800-121 [metal], 800-082 [plastic], 800-086 [plastic, 90°])
* Block to Return (Fuel Pump) – 5/16” GM Quick Connect (Dorman 800-120 [steel], 800-080 [plastic], 800-081 [plastic, 90°]) + 1’ 5/16” A1-15 hose + 5/16” hard line TBD (22” exposed, ~24” long, double flare brake line nut)
- Other Hoses (see here for pic)- Fresh Water Intake (#1 in pic) – 2x 27” long 1½” suction rated hose (Trident 250; Novaflex 250/149; MPI 250)
- Circulating (#3 & 6, Triangle to Headers) – 20” + 19” long 1” 150psi hose (Trident 200; Novaflex 130; MPI 132)
- Holy Grail Hoses (#4 & 5) – Almost impossible (special order, see here) - Powerslot Trans - Hurth HSW 450 A2 = ZF 45 A
- Trans Temp Switch (195°F) – 885178 (Bakes Online), Alto 99329, Velvet Drive 1000-140-004
- Trans Oil, Capacity – Dexron III, 2.5L (2.64 qt)
- Inner Bearing – Napa L68149
- Inner Bearing Race – Napa L68111
- Inner Bearing Seal – Napa/SKF 16404
- Outer Bearing – Napa L44649
- Outer Bearing Race – Napa L44610
- Brake Pads – ’97-00 Kia Sephia, 1991 Plymouth Sundance, 1991 Dodge Daytona, 1991 Dodge Spirit
- Brake Rotor – UFP DB35 (P21501)
- Brake Caliper – UFP DB35 (P21505/510)
- Brake Actuator – UFP A60 (P30141)
- Glue for Carpet – FlorCraft (here); DAP Indoor/Outdoor (1 gal., Amazon)
- Carpet – Corinthian Carpet (PDX), 32 oz. weight lighter than orig, 14”x14’ for engine box, pre-mark screw holes, 21’ x 7.5’ for PS205
