Originally posted by waterlogged882
View Post
The reviving of a 93 ProStar 190
Originally posted by SlickStar View PostMine has the tilt helm. Couple places I looked said it is discontinued so I am still on the original splined helm.
Originally posted by waterlogged882 View PostThanks. I have a lead on the tilt helm. It is available. I too have the tilt helm on my 93. Splined is what I was wondering about. Thanks for the confirmation. I forgot. I work on the older boats as a hobby and often get the two different configurations mixed up.
Originally posted by SlickStar View PostI would be interested in that lead. If I could get the slop out of the helm, it would really feel like a new boat. New cable helped a tad, some loose hardware too, but still has play.
Does the anchor light work? If not, turn on the switch, make sure any battery switches are on and measure voltage across the terminals in the light socket. If, only the bow light, you can crawl under the bow and measure voltage across the wires. If voltage is not present measure resistance across the switch to make sure it is closing (you could also do this using the anchor light terminals).
Originally posted by jmhjgh View PostDoes the anchor light work? If not, turn on the switch, make sure any battery switches are on and measure voltage across the terminals in the light socket. If, only the bow light, you can crawl under the bow and measure voltage across the wires. If voltage is not present measure resistance across the switch to make sure it is closing (you could also do this using the anchor light terminals).
Not sure what kind of slop in the helm you mean, but here are a couple resources that helped me when my steering wheel wobbled back and forth. I did the bushing replacement and it fixed my issue.
Here's a relatively straight forward fix for the up/down slop in older (90's?) models that use the teleflex wheel system. In essence, the problem is due to a worn
Originally posted by dfend_93_190 View PostNot sure what kind of slop in the helm you mean, but here are a couple resources that helped me when my steering wheel wobbled back and forth. I did the bushing replacement and it fixed my issue.
https://teamtalk.mastercraft.com//sh...ad.php?t=58187
