1980 S&S Restoration and Modernization
A Few Questions
Do you remove the straight line tape while the product is still wet? At what point do you spray the clear. Can the gel coat be thinned down any more to prevent the orange peel? I can't imagine the factory doing the work required to buff it down. Also, if the clear coat is on, seems like it would be sanded or buffed off.
Originally posted by ONTHECOAST View PostDo you remove the straight line tape while the product is still wet? At what point do you spray the clear. Can the gel coat be thinned down any more to prevent the orange peel? I can't imagine the factory doing the work required to buff it down. Also, if the clear coat is on, seems like it would be sanded or buffed off.
The flake + clear goes on first (3 coats was enough) followed immediately with just clear (I put on a lot - 4 coats - to bury the flake, and knowing I’d need to sand a lot to get the orange peel off). Wait a few minutes between coats.
You don’t want to thin too much or you’ll have trouble getting the amount of build you need. I thinned at 20% with Duratec high gloss.
At the factory, the gelcoat is sprayed into a perfectly smooth mold first, and they build up the fiberglass laminate on top of it. So, as long as the mold is perfect (and they spend a lot of effort to keep them perfect), there’s little polishing required.
Originally posted by waterlogged882 View PostI think gel was originally (first into the mold) intended as the release agent from the mold and it was then later (upon discovery) transitioned for use as the finish look, thus further using wax in the mold as the release agent. I could be incorrect.
Originally posted by ONTHECOAST View PostI believe you are correct. I did a tour of the Sportsman boat factory while I was there doing construction of their facilities. I do remember that was the process now that you reminded me. I have heard that people had flake resprayed under warranty. Just wondered how that was done.
Originally posted by Ironhorse View PostFlake sprayed under warranty is not done well. I have had to reject my bow cover from my prostar twice and still do not have it back. This was dropped at the dealer in April. Not impressed.Jerry
2020 X22
2018 XT22
2014 Aqua Patio
2003 Malibu Response LXi
2001 Malibu Sunsetter
1978 Ski Supreme
Originally posted by barneyferd View PostI'd say it depends entirely on the skill of the person doing the repair. I had a horrible gouge in the Black Mica last year on my X22 - the result of trying to get off my lift on a very windy day, with a pontoon in the slip next to me with an outboard in a very unfortunate position. Not my proudest day, I panicked and goosed the throttle at the wrong time with the rudder in the worst position possible. I was sick to my stomach, probably only had 10 hours on her at that time. My friends at Action assured me their guy was an artist and I would never know the difference. Same guy that did the one-off Stars & Stripes Prostar they auctioned off this summer. He did just an unbelievable job. I would challenge anyone to find the repair. I consider myself pretty critical, and I cannot find it. Wasn't cheap, so thank goodness for good insurance. But even if I hadn't, I would have gladly paid for his work out of pocket.
Sorry for the rant, lets get back to this great thread!
Originally posted by WhiskeyTango View PostWell, at least nothing has changed. Sanding still sucks.
The learning continues. There were a number of “voids”, dimples or low spots in the gelcoat that I initially thought were fisheyes. However, after sanding, many of them came out, while some were deeper than I wanted to sand through. None went all the way to the substrate.
Given that I did not have this problem with the first panel, which was new material, and recalling the number of pinholes I filled on the doghouse after removing texture while doing body work, I now think these were small pinholes that sucked in gelcoat.
The solution was to spot fill with gel, then sand off the tops and then wet sand with multiple grits.
The last pics below are after sanding to 2000 grit and then the first pass with compound. It looks “ok” and I’ll post more pics after polishing is complete.
- Likes 1
Originally posted by waterlogged882 View PostIs the room's ambient temperature fairly steady?
I may get some more sprayed this weekend and will report back on learnings. I am going to adjust my process to lay the first coat on lightly and give it a few more minutes between coats to see if dimples start appearing as I build it up.
- Likes 1
Originally posted by WhiskeyTango View PostDeck is in color. Lots of work to do this solo…
Hope everyone has a great thanksgiving.
Work on...
