1980 S&S Restoration and Modernization
  • How many gallons of foam solution? I see two gallons there (one part resin . one part catalyst).
    Looks good and gets my seal of approval. :-)
    I especially like the fillet from the hull to the floor edges. The carpet (if using carpet) will look great at that joint, as it rolls down the side and onto the floor, across that smooth transition angle.
    The outer stringer angle(s) are just as they should be.
    My understanding of the origin of the foam (the requirement, not the location) is a little different but that can be another thread discussion.
    It's coming together nicely.
    93 190
    (safe click)
    John 14:6
    (safe click)
    • Originally posted by waterlogged882 View Post
      Regarding the foam, I bought two 2-gallon kits and used over one kit, then trimmed off quite a bit.
      Yes, I’ll be using carpet and that’s why I built the fillet… to have a strong and smooth transition. I sure hope this floor never has to come out because it is very solidly attached and would be a giant PITA to remove. The original floor was attached with nails, glue and a thin strip of fiberglass along the edges. It came out easily.
      I am interested in the foam origin. I was referring to this old marketing piece. I’m guessing there is more to the story and probably a regulatory angle as well.
      • Wow, solid work - congrats, summer is coming!
        • after all the work you’ve put in I’d be inclined to have it float over not putting in some foam
          1981 MasterCraft
          19' Skier 351W PowerSlot
          • The 1.5:1 powerslot transmission is now rebuilt. Using Wouter’s thread and the manual as reference, all clutches, gaskets, o-rings, seals and steel sealing rings have been replaced. Without Wouter’s thread, I might not have attempted the rebuild, and there were a few parts in the kit I bought that Wouter didn’t use, so the manual was very useful to do a complete restoration.
            New hoses and some paint followed. A pressure test (using the most ghetto contraption I could think of to spin the transmission… yes, that’s a buffer, a socket, a nut and an old piece of hose) indicated good pressure.
            The bilge got a quick coat of epoxy based paint.
            You know what is next… maybe tomorrow?
            • Popcorn
              . Click image for larger version
Name:	Popcorn Sutton01.jpg
              93 190
              (safe click)
              John 14:6
              (safe click)
                Popcorn
                … Sutton
                • Originally posted by WhiskeyTango View Post
                  … Sutton
                  You get it.... :-)
                  93 190
                  (safe click)
                  John 14:6
                  (safe click)
                  • Just sitting there, but at least it’s off the engine stand again!
                    • Update:
                      The engine is leveled, aligned within 1/1000” and anchored. The strut required some minor shimming to get the shaft in the shaft log without contact. This was an iterative process. Lesson learned: confirm everything is good twice before putting on silicone.
                      Click image for larger version  Name:	B3BA0D8D-7E59-4D82-ADFF-2434D260BB98.jpg Views:	0 Size:	4.57 MB ID:	2702640
                      Click image for larger version  Name:	8FCE447A-D37D-4284-B6D9-CDFB7284EF54.jpg Views:	0 Size:	3.49 MB ID:	2702633
                      Motor and trans mounts are bolted though horizontally and lag screwed vertically.
                      Had to build a new mount for the upgraded steering clamp. I think the strut and rudder may have been replaced with aftermarket parts at some point as nothing went together quite like you would think it would. Rudder port has new packing.
                      Click image for larger version  Name:	B3816444-215B-42CA-85E2-498DBFDF39F4.jpg Views:	0 Size:	4.86 MB ID:	2702638
                      Shaft seal is in place and new coupler installed.
                      Exhaust hoses and tips are new. Mufflers were sanded to check for cracks and then painted and installed.
                      Click image for larger version  Name:	F8F23BFA-FD26-496D-9767-7C59B0CA2685.jpg Views:	0 Size:	5.95 MB ID:	2702631
                      Floor has been sanded (just to get it to hold carpet glue and to smooth where there were resin drips) and is ready for carpet.
                      Click image for larger version  Name:	F16EBF97-0C21-407D-984D-AA503868A917.jpg Views:	0 Size:	4.00 MB ID:	2702636
                      Click image for larger version  Name:	599EA672-A133-4738-A7A9-2CA14D42EDEF.jpg Views:	0 Size:	3.81 MB ID:	2702634
                      Platform underside got painted black and is ready to install.
                      Click image for larger version  Name:	4ED9CBA3-9C1C-4C87-A83C-0C26BFD95AD2.jpg Views:	0 Size:	3.85 MB ID:	2702635
                      Click image for larger version  Name:	A8D559AD-78CD-4261-87F9-C440635D496E.jpg Views:	0 Size:	8.19 MB ID:	2702639
                      Click image for larger version  Name:	78C7812C-D6FC-4795-9EEC-AB864F3758BB.jpg Views:	0 Size:	2.42 MB ID:	2702632
                      • Click image for larger version
                        New bracket and clamp. Pretty simple.
                        Pylon mount in and leveled.
                        Exhaust tips.
                        • Fantastic work! Can't wait to see it with the deck on it!
                          • Hopefully the platform mounting is a slight upgrade to factory. Originally this was held on by 5 lag screws through the transom into the plywood core and 2 into the ends of the stringers.
                            It is now bolted through with aluminum backing plates. Compared to modern boats, it still feels pretty sketch, but no way it’s not an improvement.
                            The outside platform fasteners are eye bolts to allow a tie down strap to the trailer, which apparently wasn’t a thing in 1980.
                            Many terrifying acts of drilling through gel coat and enlarging holes I drilled previously (all of which “shrink” when gelcoated) are complete. Next is carpet and then the deck (and more drilling).
                            • Maybe you've covered it, but what's your plan when it's finished? Are you gonna run it or sell it?
                              Hello, my name Ryan!
                              • This might be my favorite thread ever... your work looks great, and the continual updates are addicting.
                                You might be excited to reach the end, but [selfishly] I'm not.... I don't want this to end.... haha... other than maybe final pics, but you get it.
                                Boat's lookin' great!
