1994 Protour 190 Restoration
  • Originally posted by bret View Post
    I have a brand new Jefferson's Ocean ready for the water test...November, just sayin
    There it nothing that I would like better than doing the water test in November and sharing some Jefferson's Ocean with you and Rhob enjoying the moment.
    We will have to see if I can get if finish by then.
    • Does any know the correct hook up of the two air inlet hoses that hook up under the windshield pass threw the divider to the rear of the drivers foot rest. Do they both terminate at the rear of the foot rest or does one of them pass threw and terminate at the front of the bilge.
      • Originally posted by RDahler View Post
        One hose drops down through the floor and dangles loose to vent the confined space area in front of the underfloor bulkhead. The other ties into one of the two holes/vent, to vent the middle section of the bilge in conjunction with the blower.
        The transom will have two exit ports on the inside; 1) one with a short dangling hose to vent the confined space where the fuel cell resides and 2), the other vent hole accepts the hose coming from the bilge area.
        I route both hoses through the opening where the cables go through the floor up around the driver's foot well. Then tie them in to the vent port(s) accordingly.
        Free flow from front to rear to vent the confined spaces.
        Option; for me, I dangle both hoses from the front vent behind the under floor bulkhead and leave the other port open as a hand hole for when I need to replace/reroute new cables (steering, throttle, shifter). Since the photo of the rear (below), I have added a second blower in the rear to up the forced flow of that rear confined space. I also moved the battery from that same confined space (with possible fuel fumes) to the cooler hole under the passenger's seat, then put in a dual battery setup, up front with room to spare for storage.
        93 190
        (safe click)
        John 14:6
        (safe click)
        • Thanks Chuck
          You answered my question and the two photos helped jogged my memory about the two straps covering the nuts on the lifting rings. and bracket location that bolts to the under water gear.
          Well Done.
          • Any updates...sitting here at work, finished all I had to do and bored
            • Had a productive weekend got all the under water hardware reinstalled and put the cap back on the hull.
              • A beautimus process.
                93 190
                (safe click)
                John 14:6
                (safe click)
                • That Bilge!!!
                  • Very Nice Work.
                    1989 Prostar 190 351 sold
                    2008 Prostar 197 LY6
                    • That looks fantastic. Great job.
                      • I used Golf tee's to line up all the blind rivet holes in the cap and hull this should keep it in alignment as I work my way around with the new rivets. I am also adding backer washers to each rivet. This should take care of the rivet pulling threw problem that I have seen.
                        I also installed the prop shaft and seal this evening.
                        • So impressive. Can’t be said enough
                          • Looks Awesome!!!! Love seeing your updates.
                            PS your local golf shop must be happy....LOL, great idea though!
                            Cheers
                            Mark
                            '99 Mastercraft ProStar 205 330-LTR
                            • Count me in as a member of your fan club. Everything you have done is top notch.
                              Sent from my E6910 using Tapatalk
                              • Anyone else feel the need to go wax their bilge?
                                -Tim
