Loving it. Golf tee idea is genius.
1994 Protour 190 Restoration
I worked on the rudder last night the biggest challenge was moving the hull back about 6 inches on the trailer so I could slide rudder in to the port. I ended up wrapping a strap around the pylon mount and lifting the hull a little with the chain hoist so I could reposition on the trailer.
I got to pull out a few golf tee's as I started installing the countersunk rivets that go under the rub rail.
I used a short peace of rubber tubing to hold the backer washers as I set the Rivets here are some photos of the rivet job.
Originally posted by RDahler View PostI worked on the rudder last night the biggest challenge was moving the hull back about 6 inches on the trailer so I could slide rudder in to the port. I ended up wrapping a strap around the pylon mount and lifting the hull a little with the chain hoist so I could reposition on the trailer.
Great restoration. What are the plans for the boat? Keep, sale??-Tim
Making boomers great again!!Boomin'
Originally posted by CantRepeat View PostI would have gone with SS nylock nuts on the rudder port.
Originally posted by RDahler View PostThat is a good observation I sourced all new 316 marine grade Stainless Steel hardware over the entire project and could have used nylock nuts on the rudder port, strut and tracking fins. The reason I used standard nuts and lock washers has more to do with the guy under the boat trying to hold the rudder port and four large screws in position with fresh white 4200 sealant on it and at the same time I was putting a bead of black 4200 around the inserted bolts on the top side dropping the washers and lock washers and spinning the nuts down with my fingers to evenly hold the port in place. Using nylock nuts would have made this X10 times harder to assemble.-Tim
Yes. New CNC will be smooth and you should do it given where you are at in this project.
I like and have multiple good experiences w OJ props.
Others like and have food experience w ACME.
Kinda Ford vs Chevy there.
I can’t comment on which is best for powerslot. I’d go with whatever Eric at Oj says and move on….
I'll second that - OJ is great to work with, and will tell you exactly what is recommended. And you'll get a sticker and an OJ tee shirt if you order a prop from him. I don't have any Acme experience (other than old Roadrunner cartoons), and have just used OJ myself.
BTW I have a '96 Prostar 190 with powerslot, and Eric recommended a 13.7 x 17.5 LH MF Cup 1 1/8. Was Item code 454A-MF, for what it's worth. Just checked it, I replaced recently. Another cool note, if you want your old prop refurbed, he'll do that for free when you buy a new one. So good way to refurb your spare.Jeffer
1996 Prostar 190, LT1
"5 out of 4 people have a problem with statistics..."
And to throw in another opinion, I like the mid-range control and smoothness a 4 blade gives you.
Ask Rhob's opinion on the get up, he's done my boat with 3 blade and 4 blade, also driven both and mine is 1:1. I'd give you the 3 blade ACME I took off but you've got the slot.1993 25th Anniversary Limited ProStar 190, #17
