Originally posted by waterlogged882
View Post
1994 Protour 190 Restoration
Originally posted by RDahler View PostUpdate Fuel lines done, Bilge vent tubing to rear done, Updated Bilge pump installed and New control cables hooked up and adjusted.
It appears that your battery is in the rear of the boat.Last edited by waterlogged882; 11-22-2021, 05:22 PM.
Originally posted by RDahler View PostMy granddaughter has has already taken over the front of the boat and has informed me the battery needs to stay in the rear.
Originally posted by RDahler View PostUpdate Fuel lines done, Bilge vent tubing to rear done, Updated Bilge pump installed and New control cables hooked up and adjusted.If its not a competition ski boat, its always second best.
Originally posted by RDahler View PostBret she just got up on the Knee board this year the boom may be a few years off.
Chuck here are some photos of the control panel used to run the engine on the stand.
Where do I find the short extension down pipes coming off the risers please?
I see where Domed Numbers has 50% off through the 29th.
Originally posted by waterlogged882 View Post
Thank you much.
The two 3" custom made down pipes along with the fuel cell and fuel lines, battery strap, control panel and battery cables are all included with the engine run in stand. This makes up a turn key LT1 setup. It should adapt to the 351 with a minor fuel line reconfiguration, Add in the free shipping Priceless.
Chuck
Originally posted by bret View PostDecember 17th Test Run?
I ended up putting it under the engine just in front of the bilge blower.
- 1 like
Now that is wishful thinking I would have to drop the OCD for that to happen. Just finished mounting the Depth Gauge Transducer I must have moved it to ten different locations before mounting it.
