I decided to buff out the T top and Yes I spent more time figuring out how to hold it than it took to buff it.
1994 Protour 190 Restoration
Originally posted by RDahler View PostI decided to buff out the T top and Yes I spent more time figuring out how to hold it than it took to buff it.
Mine is hanging from the ceiling trusses in the shop....
Last look at the engine before I put the engine cover on. Most of the harness in the boat were made from boat trailer light wiring with molded flat connectors. I guess they thought this was a good idea at the time. Poor Quality wire with connectors that were not water proof, Rewired the harnesses using MIL-W22759/11 PTFE stranded Silver Plated Copper Wire and AMP Harsh Environment Connectors. The Perfect Pass servo harness was also reworked.3 Photos
- 1 like
Originally posted by RDahler View PostLast look at the engine before I put the engine cover on. Most of the harness in the boat were made from boat trailer light wiring with molded flat connectors. I guess they thought this was a good idea at the time. Poor Quality wire with connectors that were not water proof, Rewired the harnesses using MIL-W22759/11 PTFE stranded Silver Plated Copper Wire and AMP Harsh Environment Connectors. The Perfect Pass servo harness was also reworked.
I do have a few challenges left that will push the water test back a little. The next thing on the to do list is the rub rail I going to try and get that done this weekend. Then install the Fuel tank and close up the rear of the boat. I am going to redesign the rats nest of wires that lived behind the instrument panel I would like to be able to unplug some connectors and remove the panel for service.
The Panel also needs work like most boats of this age the lower corners were the screws go are breaking up.
- 1 like
Resealed the joint between the deck and the hull.Taped above and bellow the joint I cut the tip on calk tube for a small hole 1/16" ran the bead along the joint smoothed it with finger and removed the tape before the silicone skinned over. I used one tube of silicone and one roll of tape.3 Photos
Originally posted by RDahler View PostResealed the joint between the deck and the hull.Taped above and bellow the joint I cut the tip on calk tube for a small hole 1/16" ran the bead along the joint smoothed it with finger and removed the tape before the silicone skinned over. I used one tube of silicone and one roll of tape.
Looks good.
Thank you for the goods. I really appreciate it. I owe you a Coke. Travis was a really nice guy and his mom is just a peach.
Originally posted by RDahler View PostHinge Observer Seat 91-95 PS-190 Mastercraft # 560200 NLA
After a lot of research Found the original Stanley 342 Pivot Hinges on Ebay
My Hinges were a little loose in the pivots.
Glad you found a set of seat back hinges. Every fellow should have a set of these in the spare parts bin.
