7si 70 amp Alternator upgrade to make this work i had to up size the 10 gauge battery wire to 8 gauge fore the extra current and attach the purple wire to the I and S on the small connector on rear. I installed a new belt and set the tension to 75lb. A good way to get the belt tension right if you do not have a belt tension gauge is to twist the belt between your two fingers as far as you can twist it, 90 degrees should be very close less is to much and more is to loose.
I also upgraded the starter to a permanent magnet starter the benefit smaller, lighter and requires 50% less current to start the engine.
The last photo the engine mounted on test stand.
That is the correct starter.
I bought my starter from Go2marine there SKU 114769 (10059DRPG-LH) same price as your link but when you pull up the web sight they will offer you a $10 discount if you sign up they also do free shipping.
You will also need to replace the mounting bolts because the mounting flange is thicker on the new starter.
Here is also the Alternator info.
Alternator (7SI) 400-12160 DB Electric Amazon
2 wire plug 358-9801358 Maniac EM Amazon
Belt 6K325 ACDelco Amazon
Wow, beautiful work. I saw your post with the part number for the weatherstrip under the windshield. Are you replacing or reusing the rubber from the screw track? Would you happen to have the PN for that piece? Thanks.
Do a search on Taylor made Windshield screw cover. This should lead you in the right direction.
The original cover was black foam rubber and just pushed in the channel.
This is a IR photo I took the engine idling for 15 minutes run time from a cold start. The engine is up to temp and both Thermostats are working properly to control the engine temperature.
I just finished drilling the mounting holes for the new exhaust tips. The original tips were held on with self taping screws and I am not a big fan of securing them that way. The new tips were custom made to my specifications by Harden Marine. I just send them a Auto Cad drawing of what I want about 10 days later the box with the new Tips is on the front Porch. I made sure to position the mounting holes so I can put stainless stop nuts and washers on the mounting screws.
