Originally posted by bturner2
View Post
2003 X2 "Restoration" Thread
¡Viva 205V!
2003 X2 MCX
Just ordered up custom trailer step pads from Seadek. They're estimating 12 week lead time, so hopefully will have them before spring.
Seadek template/drawing number 34415, which is 6 pieces in total and matched up perfectly to my 2003 MC dual axle trailer.
Looks like the picture below, but I went with black embossed top layer and then black bottom layer.¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View PostJust ordered up custom trailer step pads from Seadek. They're estimating 12 week lead time, so hopefully will have them before spring.
I like those a lot. Very nice.2002, X30, L-18, Red Metal Flake (the possessed boat)
New wheels and tires showed up. Shout out to Pete at [email protected]¡Viva 205V!
2003 X2 MCX
Can’t wait to see it!!!!Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
Originally posted by brucemac View PostExciting to see the progress after week 1 and super happy to see how this are shaping up.2002, X30, L-18, Red Metal Flake (the possessed boat)
Originally posted by MC25 View PostCan’t wait to see it!!!!
Originally posted by waterlogged882 View PostNo better time than now for seat heating pads. Have the pads installed with the pigtails(s) sticking out (pre-planned location). Wiring can come later. Easy and inexpensive.
Originally posted by prostar205 View PostThat shop and the MasterCraft logo look familiar. Can't wait to see the finished product. Mine's been done for 4 years now and it still looks great.Thanks for the advice and referral! Hope you don't mind me using the same logo. Why fix what isn't broke?!
¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View PostDo you have a recommendation on a specific product? I saw a post of yours from 2018, but the SCAmazon link is no longer valid.
Just figure where you want the wiring to exit the seat location for ease of routing to a switch, then install with that in mind.
Any seat that raises, work the orientation of the pad to where the pig tail will be close to the hinge point for raising the seat.
Easy peasy.
I will say this as a tip... if you (or the installer) run a wire(s) across an area of the seat cover (sometimes near the exit point), use an Exacto knife (or similar) to cut a small trench or slot in the foam for the wire to lay in. Makes it a much nicer fit. Nothing complicated at all. A serrated knife blade works best when cutting foam...makes it a breeze and very nice edges. A straight edge, not so much, particularly on larger cuts. I use an electric bread knife with the serrated edge blade for large (thick) cuts.
For the best install, make sure the installer lays in a thin layer or pad between the foam and the vinyl cover (regardless of the heat pad). Some installers do, some do not.
Regardless of the cuts in the foam, the pads will find a home and settle in nicely once they are installed; especially with the thin padding between them and the seat cover. You'll never know they are there until you turn them on. I wallow all over my passenger's seat with my knees, etc...these pads are tough. No problems at all for me.
.Last edited by waterlogged882; 09-23-2021, 03:24 PM.
