I hope that I never find this out personally, but what are the signs of an improperly winterized boat specific to the motor? I remember reading a thread where the member wrote the boat ran fine until he checked the milky oil and knew something was wrong. Any steps in the first water test of the year that are common?
What notice does the boat give to an improper winterization?
There is no single / simple answer to this question. It ranges from the block is cracked and the boat immediately overheats, to much more subtle issues such as a tiny crack in the exhaust system that causes no immediate issue, but lets water get into a cylinder and rusts that cylinder over time.-----------------------------------
Originally posted by tjrowbot View PostI hope that I never find this out personally, but what are the signs of an improperly winterized boat specific to the engine? I remember reading a thread where the member wrote the boat ran fine until he checked the milky oil and knew something was wrong. Any steps in the first water test of the year that are common?
Internally: water in the oil is indicative of a water leak going inside the block...that's the first tell tale. It can come from several different causes / sources. Run the engine to operating temperature and maybe an extra lap, shut the engine off and look at the oil on the dipstick.
Externally: Water leaking externally is a solid indicator where you would do a visual inspection of the engine (on your knees with a good light) and look over the heads, exhaust manifold, risers, and block...look closely for physical water leaking from a crack, pinhole, or bad gasket.
Aside from that any other indicators will be in the form of a problem in some other manner, yet the root cause can be a leak or consequence of a ruptured or internally separated hose, gasket leaking, etc. as stated above.
.Last edited by waterlogged882; 02-08-2022, 07:45 PM.
Originally posted by curver900 View Postyou can always to do a cylinder leak down test... then you know before you go into the water.... if you drained the block you are in good shape..
